I am removing it to do the the electric water pump and install the block off for the water pump. I got the hoses and the water pump cover off. Also removed the 10mm bolt in the center of the "fan blades". Trying to pull on the back plate assuming the rest of the water pump slides out and it is not budging at all. Any ideas what to try?
