Looking for some insight on this issue. Cruising speed any gear around 4000 rpm, I started hearing a howling noise. Sounds like wind in a tunnel, very low pitched howl. Sounds like its coming from under the tank, and it will do it when free revved parked in neutral but I can really hear it when I'm wearing my helmet and moving. I just finished installing Brock's clutch mod and this was second ride after the install. I followed instructions to the t, I'm anal about everything on the bike, so I used correct thread locker where needed, main shaft nut was torqued with a snap-on torque wrench, everything was assembled properly. No power loss. no harsh noises, no idle problems or dead spots in the rpm, clutch bites hard, no slipping or chatter. The howl just started midway through the 40 minute ride. Any ideas would be appreciated. Thanks.
