spdjunkey
After replacing the cush drive bushings on my 99, the hub and sprocket have a visible wobble when viewed from the rear and turning the wheel while up on the rear stand. Everything is tight and aligned. The wheel and rotor both track straight and look normal. The wobble is isolated to the hub. I've tried it with and without the chain on the sprocket. Same results. Thinking it could be a bearing but they all spin smooth without feeling loose. The only other thing, is the hub spacer. It seems like it may not fit as tight as it should. At this point, I have no idea. So, any help is appreciated.
