I know! Been asked B4 susp settings?
8Daytona8
My PC must be going kaput but I can't get any thing back with the search on setting the suspension! Anyone got the #'s and clicks for a 200lb + - rider?
Oh yea 06 stocker! Or a link to the great post that was here! It said to the max settings and i was told today that was too much and i'm inclined to agree! Any found other works better.
I'll go out on a limb here and assume your street riding not racing...with that, you should be replacing your fork springs from the stock .85kg to a 1.00 kg spring... Going with a lighter, .95 spring, you will have to stiffen the settings up, and wear the spring out quicker than a stiffer spring 1.00 and softer settings. Bottom line, the stock fork springs suck.
I guess if its a sticky it won't pull up with a search like suspension? and i'm hearing a sqeeke when hitting little bumps
I have every adj maxed!
