Hello guys and gals,
I have a gravely PM148Z zero turn mower. (model 992043 i believe) On said mower I have a factory kawasaki FH641V-AS25 Engine. The problem is tha the engine seems to have a problem with misfires at high idle. It has new plugs (about 30hrs on them), new air filters, fresh oil this season. Carb has been cleaned several times and it is clean every time except for a lot of oil in the breather from the crankcase ventillation.
This is where my prolbem lies i believe. I think that the oil is slowly getting sucked into the high idle air jets and not allowing the air to mix properly with the gas. The engine is getting tired i believe. it has about 2000 hours on it and freshly adjusted valves. I did that last night to eliminate it as a potential problem. I am trying to decide if it will be worth it to rebuild the current engine or just get a new one. I found a different model on flea bay brand new for 899 shipped. Its a little more power and top of the line from kaw.
Now for the real question, how hard would it be to affix a newer FX651-DS02 engine to my mower. Provided the output shaft is the right diameter and length. The governer looks different on the newer engine as well as the attachment point for the throttle cable. I would love it if somebody on here happened to be a tech that could verify the length and size of the 2 shafts.
I have called the local dealer and they can not answer my questions. If somebody knows somebody that I can call please drop me a pm
thanks
thanks
