I Need HELP!
xFaLL3NxxSTaRx
<span style='font-family:arial'><span style='color:deeppink'>Okay, I don't know if they call it "freeze Frame" on the Busas, but the feature that records your last known speed... Now I know that on regular cars it is the last known speed when shifted and a check engine light comes on. My question is... Is it the same for these bikes or does it record just the last known speed in general?? I've tried to look it up on the net, but no such luck
</span></span>
Not built in, but you can install a SpeedoHealer and have a recall function for the high speed.
<span style='font-family:arial'><span style='color:deeppink'>Thanks! From what I have read... It only records the top speed... not every speed on a shift? Does it tell you the time and date also of that speed? Thanks for the reply!</span></span>
No just the top speed...
You can do it with a data logger. Date time, easily monitor rpm, Gear position, MPH. TPS with existing sensors. You just have to carefully select the logger so it has a puls converter. An Innovative DL32 will do it and a 512meg card will record about 140 hours of data. Not too cheap however.
