OB_Dennis D.
{{{NOTE: My original post was unreadable.}}}
I phoned a few Suzuki Dealers for a price check on the IAPS . . . $225 - $241!!! Wow, Numbnuts was right. Unbelieveable. Is this part made out of gold???
I previously posted a request for info on the IAPS, but did not receive a reply from any other members. I will ask once again.
What is the spec for this sensor's output range in terms of an electrical signal to the ECM. I did a crude test of my IAPS the other day with engine running. At idle (1150 rpm) output is 2.45V. At fast idle
(~2500 rpm) measurement increased to 2.60V,
only 150mv difference. Is this normal?
I know the sensor is working as pulling the vacuum hose off caused the engine to stall
or run EXTREMELY rough at higher rpm. Once replaced, engine again runs "normal", off idle stumble notwithstanding.
Factory set TPS too high, so I adjusted it
back to recommended setting. Didn't really help get rid of the stumble . . . maybe a little better, but generally still evident.
Did I hear right? Numbnuts, who apparently had the same stumble in a Y2k Busa, said
plugging the PAIR line solved the problem.
comments, opinions, recommendations anyone?
