Old Busa trick. Move the IAT to the ramair tube to get the true temps on the incoming air. No heat soak from the motor. Bike idles and rides around town a little smoother
You can even try to isolate the sensor (outside of box)with some kind of "aluminiumfoil" (i m german)
or these isolation wich plumbers use (dont know the term)
Cheap , quick done and often solves the problem , ....if it comes from this sensor.
