Icon gear
flewbyu
hey everybody i was looking at buying the anthem pants and their field armor boot and was wondering if their sizes run a lillte big or a little small or pretty much right on i figured someone already owned these thanks c.t
depends on your size bro-I got the Super Duty boots and Strongarm pants- jeans were good in the waist but short on the inseam-i need 36" but some 34" inseams are okay-these were not so I peeled'em with a seam ripper n pulled the legs all the way down-now they fit great and they still look good. Be careful with their lids too-usually a lil tight if ya got a big head.
FBU,
PANTS:
If you have a 34" inseam, and I mean from the floor all the way up, then you will need a 36" length and almost nobody including ICON makes those.
My suggestion, should you decide to accept, is get a pair of the Draggin Jeans made in Australia which come custom sized to your specs...check out the combat pants.  They have multiple designs and colors with full Kevlar for abrasion.
http://www.dragginjeans.com.au/products/combatPants/index.htm
BOOTS:
ICON boots run pretty true...I have 13s in the ICON Super Duty 2 design and they are a tad on the large side compared to a 13 in tennis shoes, but work fine with a thicker sock.
On a side note, I was wearing the ICON knee/leg field armor.  I went through two pair and returned both because the stitching kept coming apart.  If you have larger calves (mine are almost 18" around) they will be tight and slide down form the knee while riding.  I'm getting the Bohn armor pants to wear underneath to eliminate that problem.
Hope this helps.  I've researched endlessly to get the most protection w/out having to wear the leather pants.
<!--EDIT|Over_Easy
Reason for Edit: None given...|1155936976 -->
Do a web search for size charts for Icon. Some websites that sell gear have sizing charts based on the size of the garment.
I had to send back a TIMAX 2 jacket because it was to small. I ended up with an XXXL for a 48" Chest.
I have the field armor boots and I love them. I had to buy them 1/2 size bigger than I normally wear tho.
Don
