Mixture is too lean at idle.......
When the engine is hotter, it makes more power at idle (because a cold engine "wants" a richer micher and a hotter engine "wants" a leaner mixture) - Yours is set too lean - so the rpm goes up as it warms up.
Find a TEKA FI adjuster and have someone adjust your idle mixture - It does each one as the bike is running.
Can't do with a pc and really tough to do with a Yosh box.
You'll need to get the best mixture for the strongest idle on each cylinder, which a qualified machanic can do for you - then you'll probably have to lower the idle speed (because you'll now have an even higher idle) and the mysterious wandering idle, since the mixture will be better set for a warmed up engine - will be banished forever -
Cheers!
Marc
<!--EDIT|Marc Salvisberg
Reason for Edit: None given...|1075607042 -->
