isiahstites
Ok - I have read lots of surging problems here and was hopig for a little more input.
I have an 05' that is stock, it has a GiPro ATRE and Speedohealer. I bought the bike two months ago and it idled high from the day I bought it. I turned the idle down and the TRE off by programming ot with the (-) instead of 4,5 or 6, it seemed to be better. At stop lights in neutral sometimes the idle has a mind of it's own. In gear with the clutch pulled in the idle has a mind of it's own.
Recently I had to dis-connect the power to the GiPro which lost its 1-6 gear indication. Now the thing is all over the place, tried to re-program the gears and it would only let me do 1-3 so I disconnect the power to the GiPro. This changed how the idle acts, no at stop lights if I am in neutral it jumps up to almost 2k if I pull the clutch in it drops down to about 1500, if I put it in gear it drops down to normal idle.
So, I plan on disconnecting the GiPro completely and see where that gets me, if that doesn't fix the problem I will be looking for vaccum leaks and a TB sync.
Anything else?
Anything else?
