That didnt say much..lol I wanted to avoid any can-bus communication BS, which hard wiring into circuits can cause, so, I found a switchable acc fuse, and ran a fuse tap to it, works great, use it to power my phone, and valentine 1 with no issues
This harness will use the dealer mode connector to trigger a relay with key on ignition power, with an inline fuse on the relay, you can power a fair bit in the trunk of your hayabusa with the mating connector I provide, or even add a fuse box of your liking. 16 gauge wiring hooks to the battery terminals directly, relay mounts in front of the battery.
The toggle switch to activate dealer mode can be unplugged and only plugged in when you want to use it.
