Furball
Well I have the exhaust part done, just need to bolt the rest together....Had a few
about the full syste, and the stock header....I pulled the stock header out...when it came off there were no gaskets or rings of any kind on the header...is this normal or is there a gasket that may have been stuck in the cyl head...also
When I am bolting the Yosh header on the flange doesn't go the whole way down to the head....does this mean I may have double gaskets in there becasue the stock ones were left behind...The pipes are also running in tight clearances as well....just want to know if this is normal or should I pull the header back off and see if there were gaskets on the stock header...thanks
