It will have to be tuned as the ECU will not compensate for changes. As many miles as you put on a bike, I'd recommend using a cam built on a exhaust blank to get the right cam to bucket alignment.
Thanks Prof. I need to get the valves adjusted and was thinking of swapping cams while its appart. I guess I'll just stick with doing the needed maintenance for now.
I'd have to find some pictures. The lobes on the cams are not spaced the same. This moves the lifter to bucket contact. This could cause long term problems. It would be better to buy a cam ground on an exhaust blanks.
Oh wow that is the first I have heard of this... sounds to be VERY useful info. I would not wanna do something to my motor that is gonna shorten the life more than me running the dog snot out of it... So what cams would you recommend? Not trying to jack this mans thread. I am planning on spraying a 40-50 shot on her as well....
