I was going to confirm with my local busa mechanic but wanted to verify here cause the org is the best community. I am about to rebuild my motor with a new head gasket, freshly flat-surfaced block/cylinder head, and APE studs/nuts. My question is the camshaft position. I don't believe the manual instructions are correct because on my motor the two outside pistons are UP and the two middle pistons are DOWN. My mechanic still has my cams but I believe I only saw one arrow per cam. I believe the intake arrow was pointed towards the inside of the motor gasket and the exhaust arrow was pointed straight up. Does anyone know if thats right? Thanks.
