Mikesbaron
Generation 1.
All I'm wondering and trying to do is integrate the rear turn signals into the OEM tail light housing.
Can I simply drill a hole in each side of the housing in Mount above from each turn signal wiring in there?
Or is there a cleaner way to wire the turn signals into the actual tail light itself to make it integrated? Assuming the OEM setup has two bulbs?
Or does someone sell a kit or I can just plug it into the stock housing? Maybe an LED integrated setup that uses the stock housing?
