will6576
Morning,
i recently installed the combined tail light/indicator LED and because i have left the incandescent bulbs up front i have installed 2 x resistors to slow the flash rate down in the rear.
my problem is that now i have an irregular flash rate and happens when the engine revs a little,
i have checked the charging system and is @13.9-14.2volts even when @2-3000rpm.
would a faulty flasher relay cause this?
i have ordered a new 7 pin led compatible relay which i can still use my conventional bulbs up front.
thanks in advance for any info, lease:
Mark.
Mark.
