but no.. the busa is heavy pig and won't turn at all... may as well weld the triples in a straight line only configurations.. if you need to turn it.. stop, get off, pick thefront up and reposition it and proceed.
When I had my busa I preferred picking the rear up and bring it around rather than picking the front up. The grab bar was easier to get ahold of than trying to grab the forks below the upper fairing to do it.
All joking aside, in response to the original question... I have said before that the busa feels top heavy to me compared to the 10. I wasn't referring to picking the bike up. I was referring to where I feel the weight while riding and maneuvering the bike. Also, I might could have worded that better. Actually, it's not really "top heavy", as in... if it leans past 0 degrees sittin' still there's no stoppin' it from hittin' the ground. I guess what I really meant was that it feels to me like the busa has a higher center of gravity (COG). Not necessarily to a fault, but definitely something I could feel when going to the 10 from a busa. To me, the weight seems to be centered lower in the 10, making it balance and handle differently. Yeah, I know I'm a green horned rookie, but I know what I feel.
In comparison, the new '05 Gixxer also feels like the weight is higher in the chassis than it is on the 10. After sitting on and moving around on all the new bikes at the bike show, the only other bikes that seemed to carry their center of gravity as low as the 10 does was the '05 R6 and the CBR600RR. All the other bikes felt like the weight was at least a little higher in the frame. Fwiw, just from moving them around and rocking them side to side the weight difference between the busa and the new gixx was obvious in feel, but the center of gravity/balance seemed pretty similar. Also, those two bikes felt like they had the highest center of gravity out of all the bikes I messed around with at the show.
I've only got seat time on a busa, the 10, and limited time on a 6RR, but based on what I've felt riding those three very different bikes, I'd say that probably the only time the "top heavy"/COG issue is really, honestly noticeable
in street riding is during low speed/parking lot maneuvers. If you're aggressive enough in some good enough twisties you could probably feel a difference in the tighter switchbacks when you're *REALLY* flicking side to side, but something tells me that the weight difference between the busa and litre bikes would make as much, if not more difference in feel when flicking at speed than COG.
Again, this is just my opinion based on my little bit of seat time on three different bikes, and from getting a feel for others at the bike show and at dealer showrooms. Don't take it for gospel. Your mileage may vary... I could be wrong... etc... Not looking to convince anybody, just throwin' out my take on the issue being discussed. That should be enough disclaimer, but somehow I'm afraid it won't be... Oh well...
