yeah venting the crankcase to the pair valve stuff is the elegant way to do it BUT some tunes such as 2WDW specifically say you need blockoffs for their tune, so there goes that. for btmoto you don't, at least not my previous bike.
the harley guys for years would just vent/connect directly to the exhaust. that doesn't count as vacuum because its not, but the flow through the exhaust would keep the stuff from the engine case sucked out well enough.
however, i'm not sure that's so great either on this bike, as anyone running dual exhausts on the busa is basically venting all that gunk to your exhaust which ends in an upward angle, right? so a small amount of that crud is gonna build up in the pipe at the point where the exhausts angles upward. no good solution so just connect it all up the normal way but without a super long hose like in that pic. short hose with krankvent and little filter on the end, tucked outta the way but serviceable every so often is the way, imo.
It's the rear brake line folder over and zip tied. LOL Seriously where is the rear brake?
i dont know what you mean by this. the whole point of this mod is that the various crap such as oil vapors are NOT being fed back into the intake of the bike. this is how cars and bikes come from the factory these days, anyone can just look and youll see the hose leading to the intake from the crankcase. no thanks.Instead of the filter on the end of the crankcase hose, just run the hose into the back of the airbox
you want this crap either expelled from the engine entirely in the form of the usual hose with a little filter on the end, simple as can be and thats it (although slightly janky) OR something more elegant such as when people install a catch can on a sportscar.
on bikes, that second way is usually done in the form of some kind of hose letting all that crap go directly to the exhaust, being removed from and thereby bypassing the engine entirely. and sure as hell not going to the airbox.
another slick method to do it that second way, yeah, is plumbing that gunk straight into the pair valve assembly so that it gets fed into the exhaust stream but as above, the issue there is that at least some tunes require blockoffs so that may interfere. dunno, not dug into mine yet.
one way or another i dont see how any of this should go to the *airbox* (intake, whatever) and if you meant skipping the engine entirely by doing it the pair valve way, then yeah that might work. guess i myself will find out the quick and easy way soon =D
thats interesting. yeah i dunno anything about a piece of mesh material inside the intake of this bike, ive not cracked anything open on this. i think my bike has about 1500 miles. if it were the yamaha i could tell you all about it =D
in any case, that pair valve connection is probly the overall best way to do it but only if not running blockoffs, of course. so at least in my case, no option unfortunately so i think i'll just route my venting to the exhaust, along with a krankvent.
to find the right bung/fitting to route a hose to the exhaust (using one of the O2 bungs), just use mcmaster as they have everything. can be tricky to find sometimes though, since the amount and variety of stuff they have is absurd.
Venting the crankcase to the exhaust?
The exhaust pressure will be more than what's coming out of the crankcase vent, so it will just pump exhaust gas through the crankcase.
