Hey All:
I started to up grading the front brakes lines on the 08 busa. I got a set of Galfer SS Brake Lines. Well, what should of taken an hour to do, didn't! I have done many brake line upgrades (Hel Lines, Goodrich, etc.) before with few issues, but this just has to be a fluke! (First set of Galfer's!) I remove the stock lines...no problem. I now install the SS lines with there copper washers etc. Tighten everything up to spec. Bleed the system. Both calipers are leaking fluid from the supplied copper washers. I tighten a little more. Bleed again. Still LEAKING! So, I remove the copper washers and install the factory suzuki brake line washers (Silver). Re-bleed the system. Looking good there. Now I have bleeder leaking.... WTF! I have tightened it down snug, but not trying to strip the bleeder. I found this problem after zip-tying the brake lever for 2 hours as instructed in the instructions. I ll re-chase this problem tommorrow. Its late and time for some ZZZZZZZ! Anyone else have this problem with the washers or a bleeder. I am going to go recheck the bleeder when I get home from work. After I re-zip-tye the brake lever for an hour or so!
