Well its been several months since I crashed and I bought my 2007 back from the insurance company. My 08 is on order and I have planned to make the 07 my race bike (if thats what you want to call what I am going to do next year). With all that has been going on lately, the crash, kids and sports, family affairs, the get together I just haven't had time to look into the bike to see what was wrong... Since I am going to race the 07 I pulled the roadlok and the throttle meisters off, the bolt on the throttlemeister was bent on the contol WOW! I new there was a bunch of cosmetic damage on the bike but the core of the bike had me a little concerned. Well since life is settling down, no more grass to mow and football season is over for my son I new some free time was coming. Tonight I had absolutely nothing planned, I put the bike up on a frame stand on the front and a redline rearstand that I bought this week. I started pulling pieces off, the fairing stay, what was left of the nose cone and headlight assy, the front forks, front tire, fender and all the little pieces that go along with that.
I got everything off, turned the key on just to see if she would start and no go, I had good tail light and I put a meter on the turn signal connectors and headlight connectors and had voltage there.. Fuel pump came on but it wouldn't turn over... I checked every wire and there were not any cuts or loose wires... I checked the kickstand, gear shift, and clutch but nothing, finally I pulled the wires off the clutch switch and jumpered with a piece of wire and VIOLA she fired right up... Smooooooth..... I thought originally that the radiator had a leak in it and it still might but it looks like most of the fluid that has leaked out was from when the bike was on its side it came out the over flow line onto the inner fairing and its been trapped in there just dripping... Either way it started and sounded good...
The front wheel isnt bent and the rotors are straight.. Good news
The tire has a tear so that has to be replaced
The forks are HOSED !!!! Expensive
The fork clamp that the stabilizer connects to is bent so that needs to be replaced
The clutch assy is broken, funny thing the lever is fine but the part where the shaft goes in is broken....
Front fender shredded
Fairing stay bent all up
Gauge cluster = busted in a million pieces
Inner panels > Upper left needs to be replaced, upper right good to go.....
Side panels, scratched but repairable I think... I will do a little bod work to them and then take them to a bud that will spray them for me... The left side has a little wrinkle but nothing I dont thing I cant fix
Headlight assy is in 2 million pieces
I dont even know where the windshield is at !
