Adobe?? Photoshop? You can rename them when you get done with windows explorer. If you are using Photoshop you can change it in the preferences. It may be version dependent. Version CS it is Edit – Preferences – File Handling. You can select to use lower case by default. It is very similar in some of the earlier versions as well.
