Pretty straight forward, I installed the factory SUZ-1 connector and plugged it into the rear tail light plug which was the only one I could figure out it was supposed to plug into and the lights do not flash when the alarm is activated, there were two grey wires with male spade connectore attached to the factory harness that go to heck if I know..? Another question I had is I tapped into the orange and white wire at the vacuum control solenoid valve for the ignition disable/anti-hijack module and when I start the bike and follow the directions to activate it the engine does not shut down but all the chirps and siren goes off as described, would this happen because I was standing to close to the bike with the remote? I was right next to it.. Is the "built in battery backup" inside the MCM or do you have to have the "(BAT-5) Back-up Battery" optional accessorie?
