zx9r
I ordered some ASV levers from my dealer. I received them yesterday and attempted to install them. The clutch went on fine and couldn't fiqure out the brake. I logged on to ASVinventions and verified I had the right part number. I tried again with no luck. I called them this morning to find out that the Suzuki Hayabusa originally came out with the conventional setup (same as 07 ) and later chenged to the radial (same as the GSXR 1000,which they are currently using). So if you are deciding to buy some new levers you may to know there is two different types of levers for the 08. I hear the radials are better.
