K1+ Fuel hose connector
Narcissus
Hayabusa Immortal
Would anyone here be able to get pics of their 2001+ fuel pump connector, unhooked? I have a 2001 tank and pump and need to get the hose and joint on the injector rail.
I'm debating whether to get the OEM joint and hose (quick connect and check-valve ready) or just connect directly. Anyone done aftermarket check valves and connectors?
Narcissus,
I have already buttoned everything up for the night, but I will go out tomorrow and take pics... if you need them now, I will go and get it done. I have a K1, stock setup.
That's cool. Definitely no rush. It's going to be at least another couple weeks before I get this sprayed and finished. I just want to see if I can get away with using the current joint or if going the OEM route is worth it.
Thanks!
