K4 Busa dyno numbers from Hungary
feket663
Hello. This is my bike's dyno numbers. Power: 175,9 HP torque: approx 103,25 ft-lbs
Modification: full exhaust system, 4 original long stacks, removed PAIR system, removed lambda sensor, Power Commander IIIUsb, ported cylinder head, original air filter, small air box mod.
I would like make an intake cam on the exhaust side (or a Yoshimura Stage 1 cams) and Wiseco 13:1 pistons. How much the prospective power increase?
Thanks the answers!
Put them pistons in,some Web Cams and you'll see 200+ if your head was done by Carpenter and has the supporting mods IE valves.
