Well, if you change the Wheel, Sprocket Drum and the spacer, along with wheel bearings, retainers and maybe axel (I don't know if the 1400 axel hole is the same size). Then see if everything lines up, then maybe it will work. You might just have to buy the entire ZX 14's rear wheel assembly. It can be done. And very simply, IF everything needed is a duplicate swap, which I doubt. It would just take some time, measurements and compair parts. Might work ? But I doubt it would be as simple as just swaping out wheels.
