OB_KawAbuser
The mount is a SAENG steering stem mount, I changed the part that fits in the stem to a part from CRG who makes the excellant bar end mirror on the bike.
Spencer, can help you at CRG.
831-451-1613
spencer@constructorsrg.com
(billet internal bar end mirror adapter)
The part that SAENG sends is a cheap plastic part that does not fit the stem very well.
Consider mounting the V1 in the rear cowl, radar passes through your body.
I ran my power leads from the battery to the power tap(located in trunk) along frame spars to the front of the bike and do not have any problems. Maybe you have a loose connection(weak crimp on the connectors).
831-451-1613
