Kick stand springs
SANDFLEA85
just changed out the kickstand.seen the one spring b4 i removed it but turns out there were 3 when i removed it and they shot off before i seen where they were attached...not sure how they go... I mean,i get the idea of the one but not sure if both long springs attach at the same spot and im guessing the short spring goes on back of bolt...the search function is down for upgrades,so i have to ask......anybody?
Yep - 2 long springs go on the same spot. The smaller diameter spring goes INSIDE the larger one.
Hi, my spring losing it's tension. Hence replacing the spring. Brought the whole set and have 2 long spring on the same spot solve. But the shorter spring I got no idea where to go.
OP mention back of the bolt.
I still can't find figure out which bolt and latch to where...
Spring Number 12 spring seems like is for the gear lever...
