Kill times
cwalker2
How long do you have your ignition/injector kill set for? I'm running a stock motored bike (intake and exhaust mods - but I don't count that as real hot rodding). The tranny is stock as well. No undercutting. The shifter is a cycletek run through ECU Editor.
My kill is currently 90 msec. I think I could go to 80 or maybe 70, but I don't want to bend a shift fork to gain 0.004.
So what are people running on stock engines and trannys?
it all really depends on how close the air solenoid is to the shifter ram along with pressure/flow
My solenoid is mounted directly on my cylinder (Cycle tek, ECU editor) and .040 is no problem. If you are running 150 psi you aren't going to bend a shift fork if that works out to be a little bit short on kill time.
Run also 55 even on a 40 shot of nitrous. No Airshifter , just a quickshifter from Greg/Cycletec
Stock tranny .
