Thanks for that mate, very interesting,, I'm definitely no expert on this, but trying to get my head around it,
Tuning with Knock Sensor | Turbo
I am putting together my new hayabusa motor for my sandrail. I am nervous about getting it on the dyno and hurting it during the tuning stage. I see that Turbo XS has a Knocklite that is supposed to detect knock if it is set up right. Don't know if it will work on a bike motor. We will use...www.hayabusa.org
OK, that's why I asked you guys, any other places that could work?That plug goes into a coolant passage, I don't recommend you remove it . . .
That would work!
that's what has me scratching my head...… I thought he said the tuner is BIG CC....You may want to switch to another tuner. Knock sensors are nearly impossible to make usable in a motorcycle application with an internal gear drivetrain.
Very good point... I’ve never seen a motorcycle engine with a knock sensor, that will be why I guess!You may want to switch to another tuner. Knock sensors are nearly impossible to make usable in a motorcycle application with an internal gear drivetrain.
