1.5 pounds helps what?Yes, it helps. I don't remember the exact weight it added. 1.5 lbs comes to mind....
you can tell a difference with 1.5 pounds of weight on the axle?Controlling wheelies.
Yes, I actually could.you can tell a difference with 1.5 pounds of weight on the axle?Controlling wheelies.![]()
wee
Checked my notes 2.7 lbs.. you need to do something to secure it as the lead will shrink as it cools. I drilled mine and put a pin in it.Yes, it helps, at least it did with a stock rear arm. I don't remember the exact weight it added. 1.5 lbs comes to mind....
when you are pushing a machine at its limits, everything can make a big difference on the street? you would never know the difference... Best part of racing is all the "tweaks" you can do and hunt for ET... (second best part is not telling anyone what you did)you can tell a difference with 1.5 pounds of weight on the axle?Controlling wheelies.![]()
wee
1.5 pounds is nothing, but if you say it helps, "24 ounces " hehehewhen you are pushing a machine at its limits, everything can make a big difference on the street? you would never know the difference... Best part of racing is all the "tweaks" you can do and hunt for ET... (second best part is not telling anyone what you did)you can tell a difference with 1.5 pounds of weight on the axle?Controlling wheelies.![]()
wee![]()
The man has won championships drag racing his Hayabusa. I would tread litely newbie.1.5 pounds is nothing, but if you say it helps, "24 ounces " hehehewhen you are pushing a machine at its limits, everything can make a big difference on the street? you would never know the difference... Best part of racing is all the "tweaks" you can do and hunt for ET... (second best part is not telling anyone what you did)you can tell a difference with 1.5 pounds of weight on the axle?Controlling wheelies.![]()
wee![]()
wee
you can bow down to who ever "street et?" lol , 1.5 lbs aint gonna help! sure if you add more than a few ounces it will work.The man has won championships drag racing his Hayabusa. I would tread litely newbie.1.5 pounds is nothing, but if you say it helps, "24 ounces " hehehewhen you are pushing a machine at its limits, everything can make a big difference on the street? you would never know the difference... Best part of racing is all the "tweaks" you can do and hunt for ET... (second best part is not telling anyone what you did)you can tell a difference with 1.5 pounds of weight on the axle?Controlling wheelies.![]()
wee![]()
wee
