jermzfree
Went to Harbor Freight and picked up a cheap cylninder leakage tester for my Busa ($40) I had a couple questions on the procedure:
1. How do you know when you achieve TDC on the Busa? Is there a marking on the signal generator that tells you where TDC is?
2. Is the engine going to crank over once 100 psi is pushed into the cylinders? If so, how do you stabalize the engine?
