Leak down test.
jermzfree
I went to Harbor freight and got my discount leak down tester, read up on the procedure, and am ready to check my cylenders for leakage for the first time. I just have a question about reaching TDC. After you rotate the crankshaft to allow the top line on the startor clutch to line up with the index mark, signifying TDC, are you ready to test all 4 cylenders now? I know when checking the valves you have to rotate the crankshaft 360 degrees on two different cycles to check all the valves.
Any help greatly appreciated!
