just installed my new integrated tail light on my 08 and love it. Want to hook up the integrated signals, just crimping them onto the stock signal wiring with a insulation displacement crimp connector, so i have the stock signals and tail light signals flashing at the same time. I am aware this will speed up the flash rate, so the light came with two ginormous resistors, that i don't really want to have just flopping around in the tail. Can i just buy a flasher relay from my local auto parts store that will work? If so, anybody have an idea which one, and is it pretty much just plug and play? If i do use the resistors, i just install them inline one each wire from the tail light to the signal wiring of left/right sides correct? For instance, the light has a blue and yellow leads hanging out for the signals, so i would just crimp one resistor on each lead and then crimp the other end of the resistor onto the stock left/right signal wiring, correct? Is there a smaller resistor i could use, these things are huge, about 2" long and 1/2" thick
