mrnyc01
Jesh... Electrical problems killing me!
Ok... So I had LED's wired in my fairings for months now. No Problems! So I had 2 pods left over and put on in the front and one in the rear. It's always been on a toggle switch. I flip the switch and the lights (none of them) work and I notice smoke coming out from under the fairing. Well I take it apart spent several hours sorting out and got everthng to work. All lights front and back. So I go to work and flip them on in the the garage. NOTHING! I come home and look at the connections and the wires are burnt thru again... like they are shorting out. The wire is actually getting hot and burning thru the rubber insulation. Now mind you this my second bike. I wired my first one with no problems now all of a sudden I am having shorting issues. The only thing I can see is that you know the led's have this little flimsy wire and the harness I have it going into is thicker gauge wire (some I had laying around). It's the kind that is solid, maybe copper or something. About the same gauge but maybe just a little thicker. Should this make a difference? Do I need to buy the wire similar to the led wire? Need help... iratating the crap out of me!
