Cappo
Okay...I swapped out my OEM front turn signals for LED and they flashed faster and the left one only worked when it wanted to so I replaced the Flasher Relay with a LED Turn Signal Flasher Relay and it did slow them down but now the left signal doesn't flash at all and if I try to click it too much the fuse blows
. I also noticed that the headlight and dashboard lighting pulses slightly when I try to turn on the left signal???. BTW, I also had a Integrated Rear Taillight/Turn Signals installed. Any ideas on what my problem may be?
![banghead :banghead: :banghead:](https://www.hayabusa.org/images/smilies/banghead.gif)
