Left cowl removal
High-Gain Busa
The power point for the Right cowl removal surely saved me a lot of time... The only thing I would add to the PPT is that it needs to be slid forward after all fasteners are removed.... It doesn't exactly fall off although I was ready.
Is there anything for the left other than what the manual shows?
If not, and the weather stays crappy I'll do one.
Exactly the same... except the power point has you removing a hex head fastener that is hidden. You probably figured out this is merely a pull out wedge/plug ftg (the fastener can stay in place). Yes, you still have to pull the fairing but not fwd it is removed by pulling it to the aft of the nose.
