For some work such as suspension work the bike needs to have all the weight off the suspension like changing links.
For those who don't have an overhead crane how do you lift the bike?
When I changed out my links to raise it 1", I used my rear stand to get the rear wheel off the ground then I used a scissor jack to lift it from somewhere around the rear shock bottom bracket (memory is leaving me). I basically balanced the bike using the rearstand as a safety cradle. It worked but i was a nervous wreck doing it afraid it was going to topple over. (actually it was fairly stable).
I was looking at possibly running a plastic coated steel rod through the swingarm axle (since its a clear straight shot thru); then built a bracket I could mount a scissor lift to - to lift the rod, thus the bike. With a stable stand this seems like a possible idea. Any ideas? (plus this concept could be used to build a trailering gizmo - I think)
What do you do? (besides buying a $500 hydraulic bike lift)
excuse the brainstorming
regards
regards
