Does anyone know which Lightech Chain Adjusters fit our Gen ll? I thought I read somewhere it was the same that fit the 09-16 gsxr 1000, can someone confirm if this is correct. Thanks
I have Gillies on my Gen I and Lightechs on my R1. If I could find them for my Gen II, I would use them... I am a big fan. I will try to see what I can find...
I found some interesting information: our Gen II shares the same part number for OEM axle blocks/adjuster with the 09-16 GSXR 1000 (ADJUSTER, CHAIN LH61446-40F00, ADJUSTER, CHAIN RH61445-40F20). I'm thinking if this is the case then it is possible that the Lightech Chain Adjusters TESK9 will fit. I'm going to order a set, I will post on my results. Thanks
I have a set on my S1KR, pricey but precise alignment/adjustment is possible . Got them direct from Europe, there are some good clones out now as well that are much more economical.
