Here is one of many links on this subject: http://coastalcompucare.us/busa/id2.html Use the search engine to find information on "Hump Mod". There will be much more listed.
Thanks for the link.
I tried the search with no success.Is there a trick to using
the search?I typed in "hump mod" then scrolled down
and clicked on "all open forums"It finds nothing?
Just install the haqnd rail, then lay the hump over it to get an idea where to start cutting. Go a little at a time and you will be fine. You have to cut out more than it appears at first.
