I just installed a Lockup clutch in my busa. Im still assembling the machine, so I wont be running it until this weekend. Just wondering if anyone has experienced any problems shifting with this installed? Specifically, Im curious about running down a drag strip at WOT, pulling in the clutch to hit another gear. Have you found the clutch to be extremely hard to pull? Ive never ran a lockup before. I completely understand the concept, but Im cant imagine the clutch would work properly under those conditions. I bet the combo of a lockup and air shifter are great together though.
What are your thoughts???
Gary
p.s. By the way, my motor is in an atv frame, and our drag races are 300 foot in the sand, so I am running 4 washers on each bolt along with 2 spring tension spacers on each spring boss. This may seem like alot, but I need it to lock as quickly as possible.
Thanks
Gary
Thanks
