So I'm new to lock up clutches. I have a single stage locker and have been playing with it on the street for the last couple weeks, and will be using it for the first time on the track this weekend.
My question has to do with multiple stages of boost. If you are running 20psi on the back end, and launching with 7psi, you of course have to add enough weight to keep the clutch engaged at 20psi, but won't this cause the lockup to engage too early coming off the line, since you are only running 7psi?
Or is it simply, it'll start engaging as soon as it sees some boost and stay there?
Am I overthinking this?
