AT 180
? locktite everything!!! think of the rotating mass, sprockets are zinging at high speeds....manual says red locktite. Doesn't take much, just a drop or two. Torque EVERYTHING according to the manual. If nothing else, just go into the shop manual (sticky pinned) and print off the torque specs page. Be especially careful with the speed sensor, they have a history of coming loose and will bust your case up. If you're going to work on your own bike, buy not only a good ft/lb torque wrench, but also an in/lb wrench as well. NOT a wrench from china, this is where you need to spend the money and get a good tool....craftsman is good and usually on sale. I even torque the oil plug after an oil change....
