Anyone have any idea what can be used to loosen or disolve Locktite.
I had to remove my rear Axle Spikes, There is an all thread rod that threads into the end of the spike, It has a groove cut out in it for the cotter pin to go threw which makes it weaker at this point. I have had to take it off a couple times and was pretty sure this time the rod would snap off in the spike and I was correct, Before trying an easy out bit, Does anyone know of a way to soften locktite so I might be able to grab the small section still attached and screw it out.
