To the painters,
I plan on painting a design on my fender and hump.
Here is the plan...scuff clear with scotch brite aroound 600 grit, wipe with prep sol and tack rag, mask, spray, shade.
Now at this point does anyone spray a layer of blending clear or base coat without pigment/mica...before the first coat of clear?
I have read that any protruding aluminium or mica effects should be sealed prior to clear...I know the first few coats of clear will burry the high points. Something else I do is over reduce the last few coats of color to get a smooth look, does this create problems?
The reason I am asking...the last paint job I did, when I put on the second coat of clear down it started to bubble up around the artwork, like I put striper on it. It was a sad sight, I started over, waited two days fo color to dry, then put on the clear...no issues.
Thanks, Ryan
Thanks, Ryan
