loose mirror
busafng
The mirror stem is loose on the right side of my new addiction. It wiggles forward and back when touched, might have gotten bumped at the stealership. Doesn't move far, an inch or two. I have no idea how to tighten this up again. Any help is appreciated.
If I'm understanding correctly, you mean where the mirror connects to the nose fairing? If so, pull the rubber boot back and tighten the bolts.
Actually it seems more to be in the middle of the stem under the boot but if the whole thing is rocking then it must start at the base. Will give that a try. You and I have the same year/color bike. thanks.
Yup, went and checked it. There's a circular plate in the middle of the mirror stem under the boot. The play is there. No visible way to tighten it either. Anyone got a fix on this or just replace or live with it. Hate to have it less than perfect. Thanks.
