The Throttle Position Sensor (TPS) should be adjust after the fuel injectors are synchronized or if you are have the problem stated here.
Procedure:
1. Connect the special tool (mode select switch Suzuki part number 09930-82710 Suzuki's price is $11.55 us dollars) to the dealer mode coupler at the wiring harness, and start the engine. (you can just jumper the plug with a paper clip like on most cars) (The plug is located under the back seat, there are 2 plugs there one with about 6 wires and one with 2 wires, the 2 wire plug is the dealer mode coupler.
2. Adjust the engine rpm to 1150 rpm.
3. Look at the LCD display between the oil light and the FI light. This is the code read out. It should have a C00 displayed with a line bar in front of it. If the bar is in the center of the LCD NO ADJUSTMENT is necessary. If the bar is to the top of the LCD or to the bottom of the LCD it is out of adjustment.
4. To adjust the TPS, loosen the TORX screws and slightly move the sensor till the bar line is in the middle of the LCD display.
5. Tighten the screws to the fix the TPS.
The LCD indicates 0.4sec. /time, and two times show the correct position where it is fixed.
List of dealer mode malfunction codes that are displayed when the MSW is on
C00 none
C11 cam shaft position sensor (CMP sensor)
C12 Crankshaft position sensor (CKP sensor)
C13 Intake air pressure sensor (IAP sensor)
C14 Throttle Position sensor (TP sensor)
C15 Engine coolant temp sensor (ECT sensor)
C21 Intake air temp sensor (IAT sensor)
C22 Atmospheric pressure sensor (AP sensor)
C24 Ignition signal #1 (IG coil #1)
C25 Ignition signal #2 (IG coil #2)
C26 Ignition signal #3 (IG coil #3)
C27 Ignition signal #4 (IG coil #4)
C31 Gear Position signal (GP switch)
C32 Injector signal #1 (FI #1)
C33 Injector signal #2 (FI #2)
C34 Injector signal #3 (FI #3)
C35 Injector signal #4 (FI #4)
C41 Fuel pump control system (FP control system)
C42 Ignition switch signal (IG switch signal)
C92 Fuel level gauge signal (Gauge sending unit)
If there is more than one code present it will be indicated from small code number to larger code number.
David G.
