chucknovice
New poster here, but long-time lurker. Thanks for all the help over the years!
I've had my 2001 for ten years and it's always run noticeably rich. I finally decided to try figure out why, so I pulled off the airbox to check for cracked vacuum hoses. While I'm in there, I check the intake air temperature sensor and intake air pressure sensor. Both voltages should be 4.5-5.5 with the ignition on, but I'm reading 0.2V on both!! No codes are showing up...
I tried a different multimeter, same thing, 0.2V. Checked continuity back to the ECU plug, all good.
Now what??
Thanks
Matt
Now what??
Thanks
Matt
