I am hoping someone can offer some advice on a build I am doing. Street use but do go to the track. Will be 300+ hp.
I have a 2015 Hayabusa that has a intercooled turbo(garrett gt35r), 83 mm bore, forged Carillo rods, lightened and race balanced crank, oversized valves, port and polish. Web camshafts turbo grind .377/.366 lift and duration 270/261. Current piston choice is Wossner 9:1 low compression with no base spacer.
Is going with low compression pistons giving up a lot of HP and making the turbo work extra hard for no reason?
Would it be better to go with high compression pistons or am I headed for detonation and lower motor life? 13:1?
Thanks for any advice
